It is currently Thu Jun 26, 2025 7:46 am
PostPosted: Fri May 19, 2006 6:56 am
Hi All
Thought this might be useful to anyone who is planning.
I had a version I put together in a hurry and loved it, but having had the experience of using it, decided I would do the design justice by making a proper version, I have just finished it, so here are some pics.
Paul once again, thank you for sharing this design.
PostPosted: Fri May 19, 2006 9:07 am
Russell, nice looking jig sir. Next time you do some necks and bodies, how about some action shots for everyone? I'd like that.
PostPosted: Fri May 19, 2006 9:14 am
As my buds Hesh and Bruce have said, nice and sturdy jig Russ, i'd also like to see how it works, it's really cool!
PostPosted: Fri May 19, 2006 9:58 am
No Problem
I have some necks to fit neck week so will take some pics.
PostPosted: Fri May 19, 2006 11:41 am
Looks good Russell. Do you cut the proper angle on the neck heel before you clamp the neck into your jig?
PostPosted: Fri May 19, 2006 12:03 pm
Hi John
First of all I should emphaise that the concept for the jig is Paul Woolsons and he as I understand it adapted in from a design by Charles Fox.
The neck is square when the little studs sit in the truss rod slot to align the neck to the center, you then put the body against the straight edge which is sticking up and adjust the black nob below until you have the desired clearance at the Saddle position, the silver wing nut above it locks everthing in place. Then you route using a guide bush and thats it you have you neck angle cut for you to the correct angle, I use a downcut spiral and the neck cut is clean and fits exactly, just a tiny touch with fine paper to refine the fit.
PostPosted: Fri May 19, 2006 3:20 pm
That sounds much too easy. Let us know how this works out after a couple neck sets Russell. I'm really excited about the prospects. Sure would be nice to shave a few hours off of setting a guitar neck. All EARS and EYES. bd
PostPosted: Fri May 19, 2006 7:37 pm
Bruce I've been using a version of the jig formonths it works well, as I understand it Paul and Brock both use this jig all the time too and probably several others.
It is incrediably easy and a great time saver.
PostPosted: Sat May 20, 2006 9:56 am
Just as a side note, Craig Holden a sponsor here also sells this jig for those more inclined to buy than build. Here is his link.Don A38857.7895833333
PostPosted: Sat May 20, 2006 10:44 am
Okay, I think I finally get it.
The aluminum shaft is attached to the base which is vertical. That vertical base is adjusted to the guitar body, which is sitting in position on the top of the unit.
Adjustments are made until it fits the body. Then, the neck blank is inserted in the holder and routed to whatever adjustment was necessary to fit the body. Pretty clever. Why didn't I think of this?
This type of creative ability comes from trying to solve a great problem. Wow, Let's see, for me this info is fourth generation. Thanks Russell for the post. But it wasn't until I saw Craig's pictures on his website that I understood the jig. Pretty clever. Thanks Don A. and Craig H. Sometimes it's just good to understand, again hat's off to the Fox!
PostPosted: Sat May 20, 2006 5:14 pm
great looking jig Terry! Thanks for sharing!
